I recently discovered a fantastic workaround for synchronizing Aqara automations across different smart home ecosystems like HomeKit, Home Assistant, and Google Home. While Aqara’s Matter compatibility doesn’t directly push automations to these platforms, creating Aqara scenes as virtual switches solves the problem beautifully!
Here’s how it works:
Create a Scene in Aqara Home: Start by defining your automation within Aqara. For instance, setting your office thermostat to 18°C in the morning. Save this as a scene with a catchy name like “Office Heating 18°C.”
Synchronize via Matter: Navigate to the “Profile” section in Aqara Home, select “Connect to Ecosystems,” and choose Matter integration. Publishing your scene here transforms it into a virtual switch visible across supported platforms.
Access in Other Ecosystems: Once synchronized, this scene appears as a virtual switch in HomeKit, Home Assistant, and Google Home. You can now trigger your Aqara automation through Siri, Alexa, or even Google Assistant!
This method is a clever hack that bridges ecosystems while maintaining the advanced conditions Aqara is known for. While it doesn’t replace native automations in Home Assistant or HomeKit, it’s a fantastic way to extend Aqara’s capabilities across your entire smart home setup.
I’ve successfully used this approach to manage my lighting schedules and thermostat settings seamlessly. It’s a joy to see everything work together without the hassle of multiple apps!
If you’re looking to unify your smart home experience, give this a try. It’s a small workaround that makes a big difference in how cohesive your smart home can feel.
