After spending several days researching and watching countless YouTube videos, I finally managed to set up my Govee Lyra RGBICWW Corner Floor Lamps to perfectly sync with my T2 Govee light kit at the rear of my TV. The setup process was a bit tricky, but the result is nothing short of amazing!
Initially, I was a bit overwhelmed by the number of settings and configurations available in the Govee app. However, I discovered that the key to achieving the perfect sync lies in the ‘Full/Part’ option. Setting this to ‘Part’ allowed each lamp to display different colors at different sides of the screen, creating a truly immersive effect.
Here’s a quick rundown of how I did it:
Pairing the Devices: I started by pairing both lamps with my T2 kit through the Govee app. This process was straightforward, and the app provided clear instructions.
Configuring the Sync Settings: Once paired, I delved into the app’s settings to ensure both lamps were set to ‘Part’ mode. This allowed each lamp to independently display colors corresponding to their respective sides of the screen.
Testing the Setup: I tested the setup by playing a few videos and movies to see how the lamps reacted. The colors changed seamlessly, and the overall effect was stunning.
Final Touches: I spent some time fine-tuning the brightness and color settings to ensure everything looked perfect in my living room.
I must say, the end result is worth every minute I spent on this project. The lamps not only enhance my TV viewing experience but also add a touch of elegance to my living room decor. If you’re considering purchasing these lamps, I highly recommend giving them a try!
If anyone has any questions or needs help setting theirs up, feel free to reach out. I’d be happy to share more tips and tricks!
