T1M Issues with randomly turning on
Has anyone else had problems with their T1M light randomly turning on? I can’t figure out why and have had to use my smart switch in “dumb” mode as a result.
I don’t - but maybe someone in your family was turning the smart switch off and on by accident? For example because they have an Apple Home widget (then you don’t even have to unlock the phone)?
My T1M turns on when you cut the power and then restore it, that’s why my smart switch is in decoupled mode
Hello, welcome to the forum. First of all, check the contact going to the lamp. Second, do you have a landing of the industrial voltage below the norm. Also check the event log, maybe it will help you.
Oh, right, T1M has very tight connections, so if you have 3x1.5mm2 wires, those may disconnect if they are loose. I had to secure them with tape because the connector broke when I installed mine.
