Hey! The Aqara T2 E27 bulb (model lumi.light.agl003, firmware 31) does not respond to the standard ZCL On/Off cluster command “Off with effect” (0x40), e.g. effect ID 0, variant 0. Plain Off (0x00), On (0x01) and Toggle (0x02) work. Scene recall also works.
As a result, the bulb can’t be turned off by Philips Hue dimmer switches (RWL022) bound directly to it, because these send “Off with effect” to turn lights off. Tested via Zigbee2MQTT by sending the command directly from the developer console.
“Off with effect” is part of the ZCL lighting command set and is used by Philips and other Zigbee lighting remotes. Please consider supporting it in a future firmware update.
@patrik12 Thanks for the detailed report! That’s a really solid catch on the ZCL compliance gap.
Your testing methodology is spot-on—isolating the command via Zigbee2MQTT’s dev console and verifying that plain On/Off/Toggle work while Off with effect (0x40) gets ignored narrows it down cleanly. The fact that Philips Hue dimmers rely on this command for their direct-binding flow explains the real-world impact perfectly.
A couple of thoughts from the community side:
Zigbee vs. Thread: The T2 ships in Thread mode by default but can be switched to Zigbee during initial setup . Since you’re using Zigbee2MQTT, I assume you’re already on Zigbee mode—worth confirming for others reading this, as the protocol stack behavior could differ.
Firmware trajectory: The bulb’s at firmware 31, and Aqara has pushed updates for hub-side Zigbee stability before . Whether bulb-level ZCL command expansion is on the roadmap is harder to predict.
Your suggestion to support Off with effect is well-framed—it’s not an esoteric command but a ZCL lighting standard used by multiple ecosystems. For getting this officially logged, the most efficient path is reaching Aqara’s product feedback channels directly:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
If you don’t have an Aqara Home account, click here to create a ticket.
In the meantime, a workaround for Hue dimmer users would be binding to a compatible hub or bridge that translates the command, though I know that defeats the direct-binding simplicity you’re after.
Appreciate you sharing the packet-level details—posts like this help the whole Zigbee tinkerer community.
Just a quick heads up, I’ve got an answer from the Customer Service team. They said “Full product functionality may be limited or unavailable when using third-party Zigbee coordinators, which may explain why certain ZCL commands such as “Off with effect” (0x40) are not handled by the bulb.” and basically recommended that i buy an Aqara Hub and i should connect my devices to the Aqara Home app. I don’t see how this solves my issue.
Looks like the only option is to switch to that particular brands Hue lineup
Sad, because i really like Aqara’s bulb.
