Hi! My Aqara LED Bulb T2s, running the Zigbee firmware, reboot every time they receive a standard ZCL OTA Upgrade “Image Notify” command. You can see it: the light switches off, then fades back up to its previous brightness.
Setup
- 5 × T2 bulbs, Zigbee firmware, paired directly to Home Assistant ZHA (no Aqara hub)
- 3 ×
lumi.light.agl001, firmware 0x1E (30) - 2 ×
lumi.light.agl006, firmware 0x1F (31)
- 3 ×
- Coordinator: Sonoff ZBDongle-P (TI CC2652P)
- Home Assistant 2026.5.1, zha 1.3.1, zigpy 1.4.1, zigpy-znp 1.0.0
What happens
By default, Home Assistant (zigpy) broadcasts an OTA Image Notify (cluster 0x0019, command 0x00, payload type 0 = QueryJitter, jitter 100) every 3.9 hours, so devices check for firmware updates. About 5 seconds after each broadcast, every powered T2 re-announces itself on the network (Device Announce), i.e. it rebooted. That makes the bulbs blink roughly 6 times a day, around the clock.
Evidence
- Over 26 consecutive broadcasts, each always-powered T2 rebooted after 26 of 26, always 5–10 s after the broadcast and never at any other time.
- Other devices on the same network (Philips Hue, SONOFF, Tuya) ignore it, as expected.
- It reproduces with a unicast too: sending the same Image Notify directly to one bulb (endpoint 1, cluster 0x0019) made it reboot 5 seconds later, 7 times out of 7. Only that bulb reacted.
- The bulb never answers with “Query Next Image Request”, which is what the ZCL spec expects. As a side effect, the T2 can’t receive firmware updates from any third-party coordinator. In HA the firmware entity stays “unknown”.
Workaround
Turn off the periodic OTA broadcast in Home Assistant:
zha:
zigpy_config:
ota:
broadcast_enabled: false
The downside is that HA no longer checks other devices for firmware updates on a timer.
Questions for Aqara
- Is this a known issue in the T2 Zigbee firmware, and is a fix planned?
- Does a newer firmware than 0x1F exist, and can a bulb paired to a third-party coordinator be updated without an Aqara hub (e.g. via Bluetooth in the Aqara Home app)?
I’ll also open a ticket through the Aqara Home app and report back. I can provide full logs if useful. Thanks!
