It sounds like the relay isn’t resetting completely or might still be partially connected to the old hub. Try unplugging it entirely for a minute or so and then reset closer to the new M2 hub. If it’s only flashing for 3 seconds again, it might also be a firmware issue.
But if you turned on the „accidental deletion protection“ then the system worked correctly!
It’s not the developer teams issue- they did program that for exactly that reason
Hi, @DEChrisE.
I disagree. Accidental deletion is remote deletion (I pressed the switch 5 times, installed a relay - I pressed the button by mistake). If I deliberately delete from the APP program, this is my personal decision. Unfortunately, there is no notification when deleting from the APP, there is a notification only when you directly (physically) delete the device.
I’m going more with @DEChrisE. If I turned on the deletion prevention, it should prevent the deletion under all circumstances until I turn it off again, regardless if I try it deliberately, accidentally or from remote. It should prevent me or any other person from deletion. That additional step to turn it off when I really intend to delete it, is a reminder, heads-up and safeguard which I have implemented with full intend.
As I see (and I can be wrong), the protection ON is to avoid inadvertently delete of devices, from the device itself, permitting to delete devices only through the App.
So, if the device is deleted from the App, it should be really deleted (as happens with most of devices).
For the common User, the device was deleted, and it was removed from the App.
