Temperature-Based Automation Setup Guide
Hey everyone, I thought I’d share my experience setting up a temperature-based automation using my Xiaomi/Aqara sensors and Sonoff 4CH relay. It’s been a bit of a learning curve, but I’ve got it working smoothly now!
My Goal:
I wanted to automate my heating system so that it turns on when the temperature drops below a certain threshold. Simple enough, right? But as a newbie, I ran into a few hiccups along the way.
The Setup:
  1. Hardware: Xiaomi/Aqara temperature sensor and Sonoff 4CH relay.
  2. Software: Using OpenHAB with Paper UI for rule configuration.
Challenges Faced:
Initially, my rule wasn’t working as expected. The automation would trigger even when the temperature was above the set threshold. After some troubleshooting, I realized the issue was with the condition logic in my rule. I had mistakenly used < instead of > in my if statement!
Solution:
I rewrote the rule to ensure the condition was correctly evaluating the temperature. Here’s the corrected version:
plaintext
rule “Temperature-Based Heating”
when
Item Aqara1_Temperature received update
then
var tempAqara1 = Aqara1_Temperature.state as Number
var threshold = 20.0 as Number
if (tempAqara1 < threshold) {
logInfo(“Heating Automation”, “Temperature is below threshold. Turning heating on.”)
sendCommand(Sonoff_Outlet, ON)
} else {
logInfo(“Heating Automation”, “Temperature is above threshold. Turning heating off.”)
sendCommand(Sonoff_Outlet, OFF)
end
Tips for Others:- Logging: Use log statements to debug your rules. They helped me identify where things were going wrong.
  • Testing: Incrementally test each part of your rule to ensure everything works as expected.
  • Documentation: Don’t hesitate to refer to the OpenHAB documentation. It’s a goldmine of information!
Final Thoughts:
Setting up this automation has been a fantastic learning experience. It’s amazing how a bit of logical thinking and persistence can turn a smart home idea into reality. If anyone has questions or needs help with similar setups, feel free to reach out!
Happy automating! :smile:
