As the days get shorter and the weather turns cooler, I’ve been thinking a lot about how to optimize my home’s heating and cooling systems. One challenge I’ve been facing is managing the temperature in my living room, which has three narrow vertical south-facing windows. While these windows provide beautiful natural light during the day, they also create some issues, especially when it comes to watching TV in the evening. The reflections from the windows can make it nearly impossible to enjoy my favorite shows, and during the colder months, I’d love to take advantage of the solar heating they provide without overheating the room.
I’ve installed double roller shades with both blackout and sheer options to help with this. During the day, I keep the sheer shades open to let in as much sunlight as possible, but in the evening, I close the blackout shades to reduce glare on the TV. This setup works well, but I’d like to add some automation to make it even more efficient. Specifically, I’d like the shades to adjust based on the outdoor temperature. If it’s too warm outside, I’d like the sheer shades to stay closed to prevent the room from overheating. On cooler days, I’d like them to open to let in as much sunlight as possible.
I’ve started experimenting with some rules to automate this process. I’ve set up a rule that triggers at sunrise and uses an outdoor temperature sensor to determine whether to open or close the shades. However, I’m concerned about creating a loop that could cause the shades to endlessly open and close, which would be both annoying and potentially damaging to the hardware. I’d love to hear from anyone who has experience with similar setups or who might have some tips on how to refine my rules to avoid conflicts.
If anyone has successfully implemented a temperature-dependent shade control system, I’d be grateful for any advice or suggestions you might have. Whether it’s about adjusting the rules, choosing the right sensors, or finding the right balance between automation and manual control, I’m all ears! Let’s work together to make this setup as efficient and user-friendly as possible.
