Temperature Monitoring Success Story: Lessons Learned and Tips
Hello everyone, I wanted to share my successful journey in setting up a temperature monitoring system in my garage, which has been quite the learning experience. I hope this post can help others who might be facing similar challenges or looking to implement something similar.
The Challenge:
We have an old refrigerator and a chest freezer in our garage, which is unheated. The fridge often struggled with maintaining consistent temperatures, and we’ve had issues with doors being left open, leading to food spoilage. Traditional zwave sensors didn’t work well due to the metal environment and poor connectivity.
The Solution:
After some research and trial and error, I decided to go with a Konnected.io alarm panel and some clever DIY solutions. Here’s what I implemented:
  1. Temperature Monitoring:
    • I used DHT22 sensors for ambient temperature and DS18B20 probes for the fridge and freezer. These probes were a bit tricky to set up, but adding a 4.7k resistor improved their reliability significantly.
  2. Door Sensors:
    • Instead of adhesive zwave sensors, I opted for copper tape contacts. These were surprisingly effective and much more durable. They work by completing a circuit when the door is closed, and they’re almost invisible once installed.
  3. Stable Readings:
    • To combat temperature fluctuations, especially during door openings, I used a glass bead bottle as a temperature probe housing. This setup ensures that the readings reflect the actual food temperature rather than just the air temperature in the fridge.
  4. Notifications and Alerts:
    • I set up alerts for door status changes (if left open for more than 2 minutes) and temperature deviations. These alerts are sent to my phone via the Safety Monitor app, which has been reliable.
Challenges Faced and Lessons Learned:
  • Battery Life: Initially, the DS18B20 probes had inconsistent readings, but adding a resistor solved this issue. Always double-check your wiring and power supply!
  • Probe Placement: Finding the right spot for the probes was crucial. I ended up using silicone ribbon cables to run them into the fridge without compromising the seal.
  • Humidity and Metal Interference: The garage’s environment was a hurdle, but using the right materials and careful installation minimized these issues.
Results:
This system has been running smoothly for over three months now. It’s given me peace of mind knowing that my food is safe, and I no longer have to worry about random door openings causing spoilage. My wife is also happier knowing the fridge is consistently maintaining the right temperature!
Tips for Others:
  • Start Small: If you’re new to DIY projects, start with a small setup and gradually expand. This helps in identifying potential issues early on.
  • Use Reliable Components: Invest in good quality sensors and wiring. Cheap components might save you money upfront but could lead to more headaches later.
  • Document Everything: Keep a log of your setup, including wiring diagrams and sensor placements. This will be invaluable if you ever need to troubleshoot or expand the system.
I’d like to thank the community for all the inspiration and advice I’ve gathered along the way. It’s amazing how much you can achieve with a bit of creativity and the right tools!
Happy tinkering everyone! :rocket:
