Hi everyone, I wanted to share my experience with setting up a temperature notification rule. I recently got a temperature sensor and was excited to get it working, but I ran into a bit of a hiccup. The rule was triggering multiple notifications whenever the temperature crossed my set threshold, which was a bit frustrating. For example, if the temperature went from 19.9°C to 20.1°C, I’d get a notification, and then another when it jumped to 20.4°C. I ended up realizing this was happening because the sensor updates frequently, and each update above my target was triggering a new notification.
I wanted to figure out how to make it so I only get a single notification the first time it goes above my target. I also thought about the scenario where the temperature might dip below and then rise again, so a once-per-day restriction wouldn’t work for me. I came across some helpful resources and managed to tweak the rule to stop the multiple notifications. It was a bit of a learning curve, but I’m really happy with how it turned out now. If anyone else is struggling with similar issues, feel free to reach out—I’d be happy to share what I learned!
Here’s a quick tip: make sure to check the frequency of your sensor updates and consider adding a small delay or threshold range to prevent multiple triggers. It’s all about fine-tuning the settings to match your specific needs. Happy tinkering everyone!
