I have a Xiaomi temperature sensor that is compatible with the Aqara app and works without any problems. I also installed an E1 radiator thermostat. The problem is that I want to associate it with the thermostat. But these do not appear as options, but another Aqara temperature sensor from another room appears. Is the reason because it is an Aqara model?
Hello, yes, the Aqara TVR will only see square Aqara sensors (I’m not talking about the current other sensors). I would recommend you buy the W100, honestly, you won’t regret it.
