I have an E1 Hub with T1 Temp and humidity sensor, connected to Google Home.
I can see temp and Hum in the Google Home App… but when asking my Google Home nest hub… it cant get the Temp… but the Humidity works fine!?
So why not the temperature?? Anyone experienced this??
@therapyman It sounds like you’re encountering an interesting issue with your E1 Hub and T1 Temperature and Humidity Sensor connected to Google Home. While it’s great that the humidity readings are working fine, it’s curious that the temperature readings aren’t showing up on your Google Nest Hub.
From what I understand, the Google Home integration can sometimes have limitations or specific compatibility issues depending on the device and firmware versions. Unfortunately, the reference information provided doesn’t cover this specific issue with Google Nest Hub integrations.
Here are a few steps you might consider trying:
Check Firmware and App Updates: Ensure both your Aqara devices and the Google Home app are updated to the latest versions. Sometimes, updates can resolve unexpected issues.
Reboot Devices: Try rebooting your Google Nest Hub and the E1 Hub to see if that resolves the syncing issue.
Google Home Settings: Double-check the settings in your Google Home app to ensure that temperature data from your T1 sensor is enabled and shared with the Nest Hub.
Community Collaboration: Given the specific nature of your query, I recommend reaching out to the community to see if anyone else has experienced and resolved this issue. Sharing experiences can often lead to creative solutions!
If the problem persists, it might be helpful to contact Aqara’s Customer Service for more in-depth support or updates on integration compatibility. I hope this helps, and please feel free to share any further updates or solutions you find!
