Hey everyone! I’ve been experimenting with the pan cam mount for a while now, and I thought I’d share my experience in case it helps someone else. Moving into a new rental apartment, I wanted to avoid drilling holes, so I tried using some small Command Strips. Unfortunately, the back of the mount was too slippery, and the strips didn’t hold up as well as I hoped.
After some research, I found that using a combination of Command Strips and a high-quality adhesive pad worked wonders. The adhesive pad provided the extra grip needed, and it was easy to remove without leaving residue. Plus, it allowed me to move the cam and mount from room to room, which is perfect for keeping an eye on my dog while I’m away.
If anyone else is looking for a non-permanent solution, I’d highly recommend this setup. It’s been holding up great, and I’ve had no issues with it slipping or moving out of place. Happy mounting! ![]()
