Hey , Drop in with some insights after spending way too many weekends figuring out how to live that smart home life without owning a single Apple device ![]()
If you’re like me—a fan of Aqara gadgets but living firmly in the Android/PC/Google world—then you know the pain: most of these devices scream “HomeKit only” right out of the box. But good news, it’s totally possible to make ‘em work—and work well—without touching an iPhone or iPad.
Here’s the breakdown of how I set up my Aqara sensors, switches, and even the G4 cam to run smoothly in a non-Apple setup:
Get the Right Hub
I went with the Aqara Hub M2. It plays nice with both Zigbee and my Alexa/Google setup. No Apple needed during setup at all. -
Use the Aqara Home App
The Android version is solid. You can pair all your devices here first. From there, I connected to Google Assistant easily. Alexa works too, but it can be a bit more meh depending on the device. -
Home Assistant is a Game-Changer
If you’re serious about automation, this is worth digging into. My G4 camera, motion sensors, and door sensors all talk through Xiaomi Gateway + Home Assistant now. Some YAML wrangling needed at times, but it’s worth it. -
Workaround for Advanced Automations
Since you miss out on Siri Shortcuts and deep HomeKit scenes, you gotta get creative. I built automation flows in Node-RED + Home Assistant that trigger lights based on presence and motion, and they work! Takes a bit of trial and error but not rocket science.
Not saying it’s as streamlined as HomeKit, but honestly, once you get it all set, it’s reliable and super customizable.
Anyone else running full Aqara without Apple gear? Would love to compare setups and maybe swap some automation ideas!
