Thermostat grouping and smart schedules
I have a two radiators in the same room and both are equipped with W600. I have set smart schedules and geo fenced automations, but I have to control them independently. Is there a way to group two W600 and use smart schedules?
@hronists Great question! Yes, the Radiator Thermostat W600 supports Multi-Device Grouping, which allows multiple units to work together to maintain a consistent temperature in the same room. This means you can group your two W600s and control them as one unit.
However, there’s an important distinction to keep in mind: while the W600 supports grouping, smart schedules are executed per device rather than as a shared group schedule. According to the E1 thermostat behavior (which shares similar scheduling logic), if you control devices as a group, their temperature is executed according to their respective smart schedules unless you set a group temperature directly.
Here’s what this means in practice:
  • Grouping: Enables synchronized control (manual adjustments, geofencing triggers, etc.)
  • Smart schedules: You’ll still need to set these up individually on each W600, or use the group temperature setting for basic control
For your geofencing and automation needs, the group control should simplify things significantly. If you want truly unified scheduling, you might also explore setting up identical smart schedules on both devices or using Automation in the Aqara Home app to trigger schedule-like behavior based on time conditions.
Have you tried creating the group in the Aqara Home app yet? If you run into any issues during setup, feel free to share what you’re seeing
