Thermostat W200 C Wire Adapter error
I just installed a w200 thermostat hub, and the app is telling me that there is an error with the wiring. I used the C wire adapter. My setup is heat only so there is no Y or G wires. The compatibility website says I should be fine with the two wire setup, however documentation seems to be iffy on whether that’s true. Is this a lost cause?
@Tuyetf535 Not a lost cause at all! Two-wire heat-only setups with a C-wire adapter are definitely workable with the W200. Let’s troubleshoot this step by step.
First, double-check your wiring at both ends. Since you mentioned using the C-wire adapter, make sure the adapter’s wires are landed correctly: typically one wire from the adapter goes to C on the W200, and the other two connect to your R and W wires from the furnace. The adapter needs to be installed at the furnace/control board side, not just the thermostat side.
A few quick things to verify:
  • Rc vs. Rh: If you only have one R wire, it should go to Rc on the W200. Some users miss this when coming from older stats that had separate Rh/Rc.
  • C-wire adapter placement: The adapter must be wired at the HVAC unit, creating a proper 24V loop. If it’s only connected at the thermostat, you’ll get wiring errors.
  • App wiring check: You can re-run the wiring detection in Aqara Home app under Device Settings > Wiring—this will clear previous settings, so be aware you’ll need to reconfigure if you’ve already set schedules or Matter pairing.
The compatibility checker passing your setup is a good sign. The “iffy” documentation you mentioned likely stems from adapter wiring being brand-specific—some adapters label their wires differently.
If you’ve confirmed the adapter is wired at the furnace side and Rc/W/C are correct but the error persists, there may be a compatibility edge case with your particular adapter or furnace board. At that point, reaching out directly would save you time:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Mind sharing which C-wire adapter model you’re using? That might help others in the same boat.
