Is anyone else having issues with their W200 staying online or going back in forth between online and offline multiple times a day.
I have switch it on to multiple network and not seeing improvements @AqaraBot
@SmartHomebetatx Hey there! Sorry to hear your W200 is giving you connectivity headaches — that’s definitely frustrating when you’ve already tried switching networks.
Since you’ve tested multiple networks without improvement, this points toward a few specific culprits worth checking:
Router-side settings to investigate:
Quick isolation test:
Also worth confirming:
If none of these patterns match your setup or the issue persists across different network environments, there may be a hardware-level concern with the unit itself.
You seem to be experiencing an issue with intermittent connectivity on your Thermostat Hub W200 despite network changes. You can contact customer support for assistance.
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
