Time Rule Not Running: My Journey to a Solution
Hello everyone, I recently encountered an issue with my time rule for evening lighting, which randomly stopped working. It was quite puzzling because manually triggering the actions worked perfectly, but the rule itself wouldn’t start automatically. I suspected it might be related to the sunset setting, as it needs to fetch the time daily, and perhaps it wasn’t completing the pending action to start the rule. To troubleshoot, I cloned the rule and set a specific start time to see if the issue persisted. This approach helped me identify that the problem wasn’t with the sunset setting but rather with how the rule was structured.
After some research and experimentation, I realized that the rule might not be handling the dynamic time updates correctly. I decided to simplify the rule by using a fixed time for testing purposes, which worked seamlessly. This made me confident that the issue was indeed with the dynamic sunset time handling. To resolve this, I adjusted the rule to fetch the sunset time more reliably and ensure it updates correctly each day.
Here are a few tips I learned along the way:
  1. Check Logs: Always start by checking the logs for any error messages. They can provide valuable insights into what’s going wrong.
  2. Test with Fixed Times: If dynamic times are causing issues, testing with fixed times can help isolate the problem.
  3. Simplify and Rebuild: If a rule becomes too complex, simplifying it or rebuilding it from scratch can sometimes resolve unexpected issues.
  4. Community Support: Don’t hesitate to reach out to the community for help. Someone might have encountered a similar issue and can offer a solution.
I hope this experience helps others who might be facing similar challenges with their time rules. Happy automating!
Hi @MH8NlJg8cu , thanks for the tips.
I believe I am having the exact same issue as yourself. I followed your steps and indeed, if I hardcode times into the app, it all works seamlessly.
So something is wrong about how the system recognises that this current time of day is in the Sunset/Sunrise window I’m hoping for.
Can you explain exactly how you “adjusted the rule to fetch the sunset time more reliably”?
