Hey everyone, I wanted to share my recent experience with time synchronization issues in my smart home setup. It started when I noticed that my automated routines were consistently running about an hour behind schedule. For instance, my smart blinds were supposed to close at 7 PM, but they would only do so at 8:08 PM. This was quite frustrating, especially since I had double-checked the time settings in my Home Assistant configuration.
I tried several troubleshooting steps, including resetting the BIOS battery on my NUC, which didn’t resolve the issue. The logs indicated a time shift, but my dashboard clock was displaying the correct time, which added to the confusion. After some research, I discovered that the problem might be related to the system’s time zone settings or potential clock drift.
To address this, I decided to synchronize my system’s clock with an NTP server. This involved modifying the system’s configuration to ensure it fetches the correct time periodically. The process was a bit technical, but it turned out to be the solution I needed. Now, my routines run perfectly on schedule, and I no longer have to manually adjust everything.
If anyone else is experiencing similar issues, I’d recommend checking your system’s time synchronization settings. It might save you a lot of frustration! ![]()
