Hey everyone, I’ve been experiencing some issues with my time-triggered automations recently. It started after an update to my Home Assistant core and OS. One of my main automations is supposed to switch off my coffee maker at 8 AM every weekday, but it hasn’t worked for the past three days. I’ve tried adjusting the timing and even duplicating the action to ensure it goes off, but nothing seems to work. The same problem is affecting my energy meter helper, which is supposed to reset at midnight but hasn’t done so consistently.
I suspect the issue might be related to the time trigger functionality after the update. I’ve read through some forums and noticed others might be facing similar issues. It’s a bit frustrating because these automations are crucial for my daily routine. I’m hoping someone else has encountered this and can offer some advice or a workaround. I’m also curious if others have noticed any changes in their time-based automations post-update.
In the meantime, I’m looking into alternative methods to achieve the same results, maybe using different triggers or integrations. If anyone has successfully resolved this issue, I’d love to hear about your solution!
