Hello everyone, I wanted to share a solution I found for synchronizing the clock on my Trane thermostats with the SmartThings Hub. I’ve been dealing with clock drift on my thermostats, which can be frustrating when setting up schedules. Here’s how I tackled it:
Problem Identification: My Trane thermostats were losing time accuracy over weeks, which affected my automated routines. I knew the SmartThings Hub could potentially help with time synchronization.
Research: I explored the SmartThings Hub’s capabilities and discovered that it can send time updates to connected devices. This seemed like the perfect solution!
Implementation: I set up a routine in SmartThings that sends a time update to my thermostats every week. This ensures that even if there’s a slight drift, it gets corrected regularly.
Outcome: This setup has been working flawlessly for a few months now. My thermostats stay accurate, and my routines run as intended. It’s a simple yet effective fix!
If anyone else is struggling with clock drift on their devices, I highly recommend exploring the time synchronization features of your hub. It can make a big difference in maintaining accurate schedules and routines.
Thanks to the community for the inspiration and support! ![]()
