Transforming a Dumb Water Heater into a Smart Solar-Powered System
After years of relying on traditional energy sources for my water heating needs, I decided it was time to take a leap into the world of smart home technology, especially with the increasing focus on sustainability and energy efficiency. My journey began with a simple yet ambitious goal: to transform my basic electric water heater into a smart, solar-powered system that could maximize the use of surplus solar energy. This wasn’t just about saving money; it was about making a positive environmental impact and leveraging technology to create a more efficient home.
The Problem:
My existing setup was a basic electric boiler connected to a smart plug. While it was a start, it lacked the intelligence to dynamically adjust its power consumption based on my solar energy production. This meant that during periods of lower solar generation, I often ended up using grid electricity, which defeated the purpose of having solar panels in the first place. The boiler operated in an all-or-nothing fashion, drawing 1500W when active and nothing at all otherwise. This rigid operation wasn’t aligned with my goal of utilizing every bit of surplus solar energy.
The Solution:
I knew I needed a more sophisticated approach. After extensive research, I came across the WPC3700 from Iammeter. This device promised precise control over heating elements based on available surplus power and seamless integration with Home Assistant. It was exactly what I needed to make my “dumb” boiler smart. The WPC3700 allows for dynamic power adjustment, ensuring that the boiler only consumes power when there’s genuine surplus energy available.
The Setup:
  1. Integration with Home Assistant: The WPC3700 was integrated with my existing Home Assistant setup. The initial setup was straightforward, thanks to its Wi-Fi connectivity and MQTT support. The goal was to use surplus solar energy for hot water heating by dynamically adjusting the WPC3700’s power target.
  2. Overcoming the Feedback Loop: One of the initial challenges was the feedback loop created by the boiler’s power consumption affecting the net export reading from my HomeWizard P1 meter. To solve this, I implemented an IKEA INSPRELNING smart plug on the boiler’s power supply. This provided real-time data on the boiler’s active power draw, independent of the P1 meter’s net reading. A helper entity was created to calculate the true net export by subtracting the boiler’s consumption from the P1 meter’s reading. This ensured stable and accurate input for the WPC3700.
  3. Synchronization and Accuracy: To address potential data synchronization issues, I configured the helper entity to update only when the P1 meter updates. Additionally, an automation was implemented to force the INSPRELNING plug to update its value every second when the boiler was active. This ensured that the boiler’s consumption data was as fresh as possible, minimizing desynchronization and maintaining accuracy.
  4. Offset Adjustment: To further refine the system, an offset helper was implemented. This continuously adjusts the setpoint based on the observed difference between the commanded power and the actual power drawn. This dynamic adjustment ensures nearly perfect alignment between the intended target and the actual consumption, maximizing the use of surplus solar energy.
The Results:
Since implementing this setup, I’ve seen a significant improvement in how efficiently I use my surplus solar energy. The boiler now dynamically adjusts its power consumption, utilizing even small amounts of excess solar energy that were previously unused. This has drastically reduced my reliance on grid power for hot water, contributing to both cost savings and a lower carbon footprint.
Conclusion:
This project has been a rewarding experience, demonstrating how smart home technology can be used to create sustainable solutions. The integration of the WPC3700 with Home Assistant has been seamless, and the ability to dynamically adjust power consumption based on solar surplus has been a game-changer. I’m excited to continue refining this setup and exploring other ways to integrate smart technology into my home.
If you’re considering a similar project, I’d recommend starting with a clear understanding of your energy consumption patterns and solar generation capabilities. From there, research the available smart devices that can help you achieve your goals. The journey might be challenging at times, but the rewards in terms of efficiency and sustainability are well worth it. I’d love to hear about your experiences and any improvements you’ve made to similar setups!
