Transforming Garage Door Sensors into Binary Automation
Hey everyone, I’ve been diving into automating my garage setup and thought I’d share my journey in case it helps anyone else. I’ve got a garage door cover sensor and a binary motion sensor, and I wanted to tie them together for some smart lighting automation. Sounds simple, right? Well, it’s been a bit of a puzzle, but I’m making progress!
So, the goal was to create a binary sensor that mirrors the state of my garage door cover. When the door is open, the binary sensor should be ‘on,’ and when it’s closed, it should be ‘off.’ This would allow me to trigger lights or other actions based on the door’s state. I figured this would be straightforward, but as it turns out, it’s been a bit tricky.
Here’s what I’ve tried so far:
yaml
  • binary_sensor:
    • name: GarageDoorBinary
      state: >
      {% if is_state(‘cover.garage_door’, ‘opened’) %}
      on
      {% else %}
      off
      {% endif %}
The idea was to have the binary sensor reflect the cover’s state. It seems logical, but it just hasn’t been working as expected. The sensor doesn’t update when the garage door changes state, which is frustrating. I’ve checked the cover entity, and it’s definitely updating correctly, so the issue must be somewhere in the template setup.
I’ve scoured the documentation and forums, and I see that others have had similar issues. It seems like the template isn’t getting triggered when the cover state changes. Maybe it’s a timing issue or a problem with how the template is structured. I’m not entirely sure, but I’m determined to figure it out!
In the meantime, I’ve been experimenting with different approaches. I’ve tried using input booleans and even some custom scripts, but nothing has quite hit the mark yet. It’s been a bit of a learning curve, but I’m enjoying the challenge. There’s something satisfying about solving these kinds of puzzles, even if it’s frustrating at times.
I’d love to hear from anyone who’s successfully set up something similar. What did you do differently? Any tips or tricks that might help me get this working? I’m all ears!
On a lighter note, I’ve been impressed by how supportive this community is. Whether it’s answering questions or sharing tips, everyone seems genuinely invested in helping each other out. It’s awesome to be part of such a collaborative group. Here’s to hoping I can contribute more as I learn!
Cheers,
