I’m thrilled to share my recent DIY project that turned my old Viessmann heat pump into a smart device, all without breaking the bank! ![]()
The Challenge: My heat pump, installed back in 2007, had no data interface, making it impossible to integrate into my smart home setup. With my energy provider offering hourly pricing, I wanted to optimize when the pump runs to save costs.
The Solution: I rigged up a system using temperature sensors, relays, and Home Assistant. Here’s how it works:
- Sensors: I installed two PT500 sensors in each boiler tank to monitor water temperature. These sensors connect to the heat pump’s existing wiring.
- Simulation: By adding resistors to the sensor lines, I can simulate different temperatures. This tricks the heat pump into thinking the water is at a certain temperature, controlling when it turns on or off.
- Automation: I programmed Home Assistant to handle scheduling based on electricity prices. The system now runs during off-peak hours, significantly cutting my energy bills!
Key Tips:
- Calibrate Sensors: Test the resistance of your sensors to ensure accurate temperature readings.
- Safety First: Set maximum temperature limits to prevent overheating.
- Fail-Safe: Configure the relay to default to the original state during power outages.
Results: After two months, the system is running smoothly. I can now control the heat pump from anywhere and it automatically adjusts based on real-time energy prices. Plus, I built a custom dashboard in Home Assistant to monitor everything!
If you’re looking to retrofit older appliances, I highly recommend exploring DIY smart solutions. It’s a bit of work upfront, but the savings and convenience are well worth it! ![]()
Would love to hear if anyone else has done something similar or has tips to improve my setup! ![]()
