After a year and a half of using Homey, I decided to switch to the Fibaro Home Center 2, and I’m thrilled with the results! While Homey was a great concept, it had some reliability issues, especially with Z-Wave communication and device integration. Let me share my journey and why I believe Fibaro is a better fit for my smart home setup.
Challenges with Homey
- Z-Wave Communication Delays: Simple flows, like turning on hallway lights with motion detection, often failed or worked inconsistently. This was frustrating, especially when it worked flawlessly in earlier versions.
- Dimmer Issues: The elegant dim-on/dim-off effect stopped working after an update, leaving my lights to turn on abruptly.
- Device Compatibility: Bosch Home Connect appliances and Spirit Z thermostats were unreliable, with some thermostats failing to respond to commands.
- Google Home Integration: While improved, there were still occasional errors, like turning on all lights instead of just the kitchen ones.
Why Fibaro?
- Reliable Z-Wave Plus Support: Fibaro’s Z-Wave Plus ensures smoother communication, resolving most of the issues I faced with Homey.
- Advanced Flow Management: Fibaro’s intuitive interface makes creating and managing flows a breeze, and the Tablet app is a game-changer for controlling my home on the go.
- Backup Options: The ability to back up my system to the cloud or a USB stick gives me peace of mind.
- Seamless Device Integration: Fibaro supports a wide range of devices, and I’ve noticed a significant improvement in reliability across all my connected devices.
My Experience with Fibaro Home Center 2
- Motion Detection Flow: Works perfectly now, with the dim-on effect back and running smoothly.
- Thermostat Control: All Spirit Z thermostats respond instantly to commands, keeping my home at the right temperature.
- Bosch Appliances: While still not directly supported, Fibaro’s compatibility with Z-Wave devices ensures smoother integration with my existing setup.
- Tablet App: Mounted in my hallway, it’s become my central hub for managing lights, thermostats, and security.
Conclusion
While I’m sad to say goodbye to Homey, Fibaro’s reliability and advanced features make it the better choice for my smart home needs. If you’re considering an upgrade or starting fresh, I highly recommend exploring Fibaro’s ecosystem. It’s been a smooth transition, and I’m excited to continue building my smart home with such a dependable system!
Cheers to smarter living! ![]()
