Hey everyone! I wanted to share my experience with creating a transparent tile for controlling night mode using a virtual switch. This idea came to me when I wanted to arm or disarm the night mode without affecting the visibility of other elements on my dashboard. Let me walk you through how I approached this and the solution I found.
First, I realized that having a transparent tile would allow me to place it over my existing HSM tile without obstructing the view. The challenge was ensuring that the tile only affected the night mode switch and didn’t interfere with other switches or elements on the dashboard. I decided to use a virtual switch specifically for this purpose, which would send the necessary commands to arm or disarm the night mode.
I started by creating a virtual switch item in my OpenHAB configuration. This item would act as the trigger for arming or disarming the night mode. Next, I designed a transparent tile using the default card template, assigning the virtual switch to it. To make it truly transparent, I adjusted the tile’s opacity settings in the card configuration. This way, the tile blends seamlessly into the background while still being functional.
I also made sure that the virtual switch didn’t interfere with other switches or elements on the dashboard. By isolating its functionality and ensuring it only sends commands related to night mode, I maintained the integrity of the rest of my setup. This approach not only solved my problem but also streamlined my dashboard’s interface, making it more user-friendly.
Overall, this project was a great learning experience. It taught me how to customize tiles and items to meet specific needs while maintaining a clean and organized dashboard. I hope this helps someone else who might be looking to achieve a similar setup!
If you have any questions or suggestions, feel free to reach out. Happy tinkering! ![]()
