Hi everyone, I wanted to share my experience with the Shelly Dimmer 2 and how I managed to resolve a connection issue I encountered. Earlier this month, I installed a new Shelly Dimmer 2 in my home. Initially, everything seemed to be working perfectly—I set it up on my Wi-Fi, assigned it a static IP, and connected it to the Shelly Cloud. The firmware was up to date, and I couldn’t have been happier with how smoothly it was going.
However, after integrating it into my home’s electrical system, I noticed that the device was no longer showing up as online in the Shelly app. It was frustrating because I could access the device’s web interface through my PC, but the app kept showing it as offline. I checked online forums and found that others had experienced similar issues, with the general consensus being that contacting Shelly Support was the only solution.
Determined to resolve the issue on my own, I decided to try a hard reset of the device. I removed the dimmer from the electrical box and held down the reset button for about 10 seconds until the LED indicator started flashing. I then reinstalled it and powered it back on. To my delight, the device reconnectd to my network and the app showed it as online once again!
Since then, the Shelly Dimmer 2 has been working flawlessly. I can control it through the app, integrate it with Alexa, and even automate it with my smart home system. This experience taught me that sometimes, a simple reset can solve seemingly complex issues. I would recommend trying this before reaching out for professional support.
If anyone else is experiencing similar problems, I hope this story helps you troubleshoot and fix your Shelly Dimmer 2. Happy smart home tinkering! ![]()
