I’ve been trying to add some Aqara Door Sensors to my deCONZ setup, but I’m running into some issues. My setup is a Raspberry Pi 4 with Home Assistant’s deCONZ add-on, firmware version 26660700, and deCONZ version 2.12.06. I’m using a ConBee II device with an USB extension cable. The sensors appear as 0xC963 in deCONZ, but I can’t get them to work properly.After trying to reset my gateway and changing the channel to 15, nothing seems to work. I’ve attempted to add two different sensors, and both have the same issue. Looking at the logs, I see messages like ‘drop request to zombie (rx = 0)’ and ‘unknown node 0x54EF44100025B794 (0x2792), lqi: 71’. This suggests that the gateway isn’t communicating with the sensors as it should.I’m wondering if there’s something wrong with my network configuration or if there’s a specific setting I need to adjust in deCONZ. Has anyone else experienced similar issues with Aqara sensors? Any advice or suggestions would be greatly appreciated. I’m really looking forward to getting these sensors up and running to complete my smart home setup.
