I recently updated my Home Assistant installation to version 0.81.0 from 0.80.1, and it was a bit of a rollercoaster! After the update, my system didn’t start up as expected, and I was left staring at the logs trying to figure out what went wrong. Here’s my journey through the problem and how I managed to get everything back on track.
The Problem
After updating, I noticed that Home Assistant wouldn’t start. The logs were filled with errors related to the event loop being closed, which I wasn’t entirely sure how to interpret. I tried rebooting the Raspberry Pi, checking the configuration files, and even reinstalling some dependencies, but nothing seemed to work. It was a bit disheartening, especially since I rely on Home Assistant for so much around the house.
The Investigation
I started by looking at the logs more closely. The errors pointed to issues with the event loop, which I understood is a critical part of Home Assistant’s operation. I did some quick research and found that similar issues had been reported in the past, often related to changes in Python versions or specific packages. I checked the packages mentioned in the logs and noticed that async-timeout had been updated. I wondered if this might be the culprit.
The Solution
After some trial and error, I decided to completely reinstall Home Assistant. I backed up my configuration files, uninstalled everything, and did a fresh install. This time, I made sure to install the latest compatible versions of all dependencies. To my relief, everything started up smoothly after the reinstall. It turns out the issue was with an incompatible package that the update hadn’t handled properly.
Lessons Learned
This experience taught me the importance of keeping backups and staying updated with compatibility notes. It also highlighted how resilient the Home Assistant community is—there are always solutions out there if you look hard enough. If you’re ever stuck with an update issue, don’t hesitate to reach out to the community or try a fresh install. You never know what small tweak might make all the difference!
