I recently encountered an issue with the Home Connect integration in my smart home setup, and I thought I’d share my experience and solution in case others are facing similar problems. Here’s what happened and how I resolved it:
The Problem
My Home Connect integration was working perfectly until one day, some entities started showing as “unavailable.” Specifically, my washing machine’s power consumption sensor and remaining runtime status were not updating. This was frustrating because I rely on these metrics to monitor energy usage and plan my laundry schedule effectively.
I decided to create an automation that would restart the Home Connect integration whenever certain conditions were met. The conditions I set were:
- When the washing machine’s power consumption exceeds 50 watts.
- When the remaining runtime entity becomes “unavailable.”
The Challenge
The main challenge was figuring out how to programmatically restart the Home Connect integration. Unfortunately, Home Connect doesn’t have a built-in “reload” button or a straightforward method to trigger a restart. After some research and trial and error, I found a workaround that involved using Home Assistant’s REST API to refresh the integration.
The Solution
Here’s how I implemented the automation:
Identify the Integration ID:
- Navigate to the Home Assistant developer tools.
- Go to the Services tab and search for
homeassistant.restart_entity. - Execute the service with the Home Connect integration entity (usually
integration.home_connect).
Set Up the Automation:
- Use the
numeric_statetrigger for the power consumption sensor. - Use the
statetrigger for the remaining runtime entity. - Combine both triggers using a logical AND condition.
- When both conditions are met, call the
homeassistant.restart_entityservice.
- Use the
Here’s the YAML configuration I used:
yaml
automation:
alias: Restart Home Connect Integration
trigger:
- platform: numeric_state
entity_id: sensor.washing_machine_power
above: 50
- platform: state
entity_id: sensor.washing_machine_remaining_time
to: unavailable
condition: and
action:
- service: homeassistant.restart_entity
data:
entity_id: integration.home_connect
The Outcome
After implementing this automation, I noticed that the Home Connect integration now restarts seamlessly when the specified conditions are met. This has resolved the issue of entities showing as “unavailable,” and my washing machine’s metrics are updating correctly again.
Tips for Others
If you’re experiencing similar issues with integrations in Home Assistant, here are a few tips:
- Check Logs: Always start by reviewing the logs in Home Assistant. They can provide valuable insights into what’s going wrong.
- Test Triggers Individually: Before combining multiple triggers, test each one separately to ensure they’re working as expected.
- Use Developer Tools: The developer tools section in Home Assistant is incredibly powerful for troubleshooting and testing custom automations.
While this issue was a bit of a hurdle, it gave me the opportunity to dive deeper into Home Assistant’s automation capabilities. I’m now more confident in setting up custom solutions for my smart home needs. If anyone else is struggling with similar integration issues, I hope this post provides some guidance!
Happy automating! ![]()
