Hi everyone, I’m reaching out to see if anyone has encountered and resolved an issue similar to mine. I’ve been trying to integrate my LG TV with Home Assistant using the LG webOS TV Integration, but I’m running into some problems. The TV is on the same network as my Home Assistant setup, and I’ve double-checked the IP address to ensure everything is correctly configured. However, every time I attempt to connect, I receive an error message indicating a failed connection. I’ve tried removing the integration and re-adding it, but the issue persists. I’m wondering if there are any specific settings on the TV that might be causing this problem. For instance, are there any IP control settings within the TV’s menu that I need to adjust? I’m also curious if others have faced similar issues and how they managed to resolve them. Any advice or insights would be greatly appreciated. Thanks in advance for your help!
