I recently encountered an issue while conducting Matter Test Harness testing, specifically with TC-IDM-10.2. Despite successfully setting up the test environment, I faced a failure during the test execution. The logs indicated a problem with the Python test step, and I noticed some peculiarities in the UART output, including a ‘NO DEVICE BOUND’ message.
To address this, I meticulously reviewed the logs and configuration files. I discovered that the binding table couldn’t be loaded, which seemed to be a critical factor in the test failure. I also examined the device configuration details, ensuring all parameters such as the QR code, setup code, and discriminator were correctly set.
One of the key steps I took was verifying the OTBR (OpenThread Border Router) setup. I ran several commands to check the state of the OTBR container and confirmed that it was functioning correctly. This involved executing sudo docker exec -ti otbr-chip ot-ctl state leader to ensure the OTBR was in the leader state.
I also explored the possibility of a communication issue between the device under test (DUT) and the test harness. This led me to check the PICS (Product Information and Configuration Setup) configuration, ensuring that all necessary clusters and attributes were properly enabled. I reviewed the provided PICS file and made adjustments to align it with the test requirements.
Another aspect I investigated was the network configuration. I verified that the Wi-Fi and Thread settings were correctly configured in the test harness, ensuring seamless communication between the DUT and the test environment. This included checking the on-mesh prefix, channel, and network key to ensure they matched the expected values.
Through this troubleshooting process, I learned the importance of meticulous log analysis and the critical role of proper device configuration in Matter testing. I also recognized the value of community support and resources in overcoming technical challenges.
In conclusion, while the initial test failure was disheartening, it presented an opportunity to deepen my understanding of Matter testing and device configuration. I hope sharing my experience can assist others facing similar issues and encourage a collaborative approach to problem-solving in the smart home ecosystem.
