I recently encountered an issue while setting up a new OpenHab server where I couldn’t send raw data via the NanoCUL, despite the device working on my old server and through Windows. Here’s how I approached solving the problem:
Permissions Check: I verified that the
/dev/ttyUSB0device hadchmod 777permissions, allowing all users to read, write, and execute. However, the device owner wasroot:dialout, so I ensured that the OpenHab user was part of thedialoutgroup. Adding the user to this group resolved potential permission issues. -
Firewall and Security Software: I checked if any firewalls or security software were blocking access to
/dev/ttyUSB0. Usingiptablesand reviewing firewall logs helped confirm there were no blocks, ensuring the command could reach the device. -
Device Mode Verification: Since the NanoCUL was functioning in monitor mode, I reset it to ensure it was in the correct mode for sending data. Cycling the power on the device also helped confirm it wasn’t in an unintended state.
Process Locks: I used
lsof /dev/ttyUSB0to check if any processes were holding the device open. Killing any such processes freed up the device for use. -
Command Line Testing: I tested the
sudo echocommand outside of OpenHab to isolate whether the issue was within OpenHab or a broader system problem. Success here indicated the problem was configuration-specific to OpenHab. -
OpenHab Logging: Reviewing OpenHab’s logs provided insights into any errors during command execution, helping pinpoint configuration issues within the binding or setup.
By systematically checking each of these areas, I identified that the OpenHab user needed to be in the dialout group, and there were no underlying firewall or process issues. This approach resolved the transmission problem, allowing raw data to be sent successfully through the NanoCUL on the new server.
