I recently started experimenting with NFC tags to automate certain tasks in my smart home setup, and I must say, it’s been an interesting journey. Initially, everything worked smoothly—I set up a tag to toggle a helper entity when scanned. However, I soon encountered a peculiar issue: whenever I scanned the tag on my iPhone and triggered the automation through the HA app, the automation would fire twice instead of once. This duplication was perplexing, as there were no duplicate entries in my system, and the traces and history logs confirmed that the automation was indeed being called twice upon each scan.
I began by questioning whether this was a bug on the iPhone’s end or perhaps an issue with the HA app. I tested the setup on different devices and environments, but the problem persisted. After some research and reaching out to the community, I discovered that this behavior might be related to how NFC signals are interpreted by mobile devices. Some devices, especially iOS, have a tendency to detect NFC tags multiple times within a short period, leading to repeated triggers.
To mitigate this, I explored a few solutions. First, I adjusted the sensitivity settings on my iPhone to reduce the likelihood of multiple detections. Additionally, I modified my automation logic to include a debounce mechanism, ensuring that the automation would only execute once within a specific timeframe. This involved adding a conditional check in my automation workflow to ignore subsequent triggers if they occurred too close in time to the initial one.
After implementing these changes, the issue was resolved, and my NFC automation worked as intended. This experience taught me the importance of considering device-specific behaviors and the value of incorporating debounce mechanisms in automation setups. It also highlighted the importance of community support in troubleshooting such issues.
If anyone else is encountering similar problems with NFC automation, I recommend checking your device settings and considering the implementation of debounce logic in your automations. Happy automating!
