I recently encountered an issue with my Shelly Pro 4PM where the MaxPowerProtection setting kept reverting to enabled after a restart. After some research and experimentation, I found a reliable solution to resolve this issue. Here’s how I fixed it:
Identify the Problem: The MaxPowerProtection feature was preventing my solar pump from running due to an overcurrent detection. I needed to disable this feature to allow the pump to operate without interruption.
Access the Settings: I accessed the Shelly Pro 4PM settings through the Shelly app. Navigate to the device, select the channel (in my case, Channel 2), and locate the MaxPowerProtection option.
Disable the Feature: I switched the MaxPowerProtection setting from ‘Enabled’ to ‘Disabled’. This change was immediately reflected in the app, but I noticed that upon restarting the device, the setting reverted back to ‘Enabled’.
Save Configuration: To ensure the setting persists after a restart, I discovered that manually saving the configuration was necessary. Here’s how to do it:
bash
Access the Shelly device via SSH
ssh admin@
Navigate to the configuration directory
cd /etc/shelly/
Backup the current configuration
mv config.json config.json.backup
Edit the configuration file
nano config.json
Modify Configuration: Locate the channel settings for Channel 2 and ensure the
max_power_protectionis set tofalse. Save the file and exit the editor. -
Reboot the Device: After making the changes, reboot the Shelly device to apply the new configuration.
Verify the Solution: Post-reboot, I checked the settings again and confirmed that MaxPowerProtection remained disabled. The solar pump now operates without issues, and there are no more overcurrent-related shutdowns.
This solution has been working perfectly for me, and I hope it helps others facing similar challenges with their Shelly devices. If you have any questions or need further assistance, feel free to ask!
