Troubleshooting Shelly1 Firmware Update Issues
I’ve been trying to update my Shelly1 devices from version 1.9.0 to 1.9.3, but it’s been a bit of a challenge. Let me share what I’ve encountered and what I’ve tried so far in case someone else is facing the same issue or has a solution to offer.
First, I noticed that when I attempt to update through the web UI, the page refreshes after about 10 seconds and just says, ‘You have the latest version.’ But then, a few seconds later, it goes back to showing that there’s a new version available. It’s a bit frustrating because it feels like it’s stuck in a loop. I’ve tried this multiple times, but the result is always the same.
I also checked the devices’ connectivity. They do have access to the internet since their time updates correctly, and they’re not cloud-connected. I’ve also ensured they have static IPs, so that shouldn’t be the issue. I’ve tried doing a factory reset, but that didn’t help either.
Has anyone else experienced this problem with Shelly1 devices? I’m curious if there’s a workaround or a different method to force the update. Maybe there’s a way to manually update the firmware or check for any hidden settings that might be causing this issue.
If anyone has successfully updated their Shelly1 devices from 1.9.0 to 1.9.3, I’d love to hear about your experience and what steps you took. Any advice or suggestions would be greatly appreciated!
Thanks in advance for your help!
