Troubleshooting SNMP Integration with Ledvance Lamps
Hey everyone, I’m reaching out to see if anyone has successfully integrated Ledvance Wi-Fi lamps using the SNMP integration in Home Assistant. I’ve been trying to get this working for a while now, but I’m hitting a bit of a snag.
Here’s what I’ve done so far: I’ve configured the lamps using localTuya, and they show up correctly in the Home Assistant interface. The lamps are visible, and their states are updated when I toggle them via the Ledvance app. However, when I try to control them through Home Assistant, nothing happens. There are no errors in the logs, which makes it a bit tricky to diagnose.
I suspect the issue might have started after the lamps experienced a power outage. I had to unplug them and restart them, and since then, they haven’t been responding through Home Assistant. It’s possible that a recent update might have caused this, but I’m not entirely sure.
I’ve tried a few troubleshooting steps: I’ve checked the SNMP settings, ensured that the base OID and other parameters are correctly configured, and even restarted the Home Assistant service. Unfortunately, none of these steps have resolved the issue.
If anyone has encountered something similar or has any tips on how to get the SNMP integration working smoothly with Ledvance lamps, I’d be really grateful for your insights. Let’s hope we can figure this out together! Thanks in advance for your help.
