I replaced my orig WS-USC01 single rocker no neutral because it stopped working. The new one - same model also doesn’t work. I verified Line and Load are good and wired correctly.
The switch controls the bottom sockets of 2 outlets. I have a couple of small lights plugged into each of the bottom sockets. The lights appear to have small fluorescent bulbs.
When it turned I. The first time the lights came on on the wall outlets and a slow red flashing led on the switch.
When I push the switch to enter pairing mode, the outlets turn off and won’t come back on.
Occasionally the LED on the switch flickers. I noticed the bulbs in my light are also flashing but not turning on.
Is there a minimum load required on the circuit before the Aqara switch will work?
Any help would be appreciated.
Getting ready to revert to a dumb switch if I can’t get this working.
No, the switch should just work as long as the connections are ok and the circuit is not open. Check if a dumb switch also works in this circuit (and if the lights flicker). If the wiring is ok (and there are no electrical problems) then it means the switch is faulty (if you bought both from the same seller, like Amazon, you might have gotten previously returned items)
Thanks. Aqara reached out to me and as it turns out the switch w/o Neutral needs a min load of 16 Watts for fluorescent bulbs. I added more load and everything is working again.
Thanks for the reply to my forum post.
Much appreciated
Thanks for the info, I knew fluorescent bulbs work a bit differently in terms of electrical conductivity, but I didn’t know it affected the switch.
Your experience may help other people on the forum in the future
Good that support has already given you the info. Marking as solved for future needs.
