Hey everyone, I’ve been having some trouble with my Wyze Cam Pan v3 cameras and thought I’d share my experience in case it helps someone else. I recently purchased two Wyze Cam Pan v3 units to enhance security around my home. Everything went smoothly during setup, but I quickly noticed that the cameras weren’t recognizing the SD cards I inserted. This was frustrating because recording is a key feature I rely on for security monitoring.
I started by checking the SD cards themselves. I used two different 32GB cards that I knew worked with other devices, but the cameras still didn’t recognize them. I even tried factory resetting the cameras and reconfiguring them, but the issue persisted. I reached out to Wyze support, and they were helpful but couldn’t resolve the issue immediately. They suggested trying different SD cards, which I did, but the problem remained.
After some research, I came across a few forums where others had similar issues. It turns out that the Wyze Cam Pan v3 has specific SD card compatibility requirements that aren’t widely documented. Some users reported success with Samsung and SanDisk cards, so I decided to try those. I purchased a Samsung 32GB SD card, and to my relief, the camera recognized it immediately! The recording started without any issues, and I could review the footage through the Wyze app.
This experience taught me the importance of checking compatibility lists before purchasing accessories for smart devices. It also highlighted how valuable community support can be when troubleshooting issues. I’m now confident that my cameras are working as intended, and I can focus on setting up additional security features around my home.
If anyone else is having trouble with their Wyze Cam Pan v3 and SD cards, I recommend trying well-known brands like Samsung or SanDisk. Hopefully, this tip helps you avoid the same frustration I faced. Thanks for reading, and happy smart home hacking!
