Hi everyone! I wanted to share my experience with getting Wyze cameras to stream properly in Home Assistant. After some trial and error, I finally got it working, and I thought I’d document the process in case others are facing similar issues.
First, I’ll start by acknowledging that setting up Wyze cameras in Home Assistant can be a bit tricky, especially if you’re new to the platform. I remember feeling a bit overwhelmed when I first tried to integrate my Wyze cams, but with persistence, I managed to figure it out.
One of the key things I learned was the importance of ensuring that the RTSP firmware is installed on your Wyze cameras. Without this, streaming won’t work as expected. I also discovered that using the correct camera type in Home Assistant’s configuration is crucial. I tried both the ffmpeg and generic camera types, but the ffmpeg option worked best for me once I fixed the av dependency issue.
Here are a few tips that might help others who are struggling with similar issues:
- Check Your RTSP Settings: Make sure your Wyze cameras are set up with the correct RTSP firmware. You can check this in the Wyze app.
- Update Home Assistant: Ensure you’re running the latest version of Home Assistant, as updates often include bug fixes and improved compatibility.
- Install FFmpeg Properly: If you’re using a Raspberry Pi, install FFmpeg with H264 support. This can be done via the command line or using a guide like this one.
- Double-Check Configuration: Review your
configuration.yamlfile to ensure there are no typos or incorrect paths. I spent a good amount of time troubleshooting a simple typo before realizing my mistake.
Finally, I want to thank the community for their support and resources. Without the wealth of information available on forums and documentation sites, I wouldn’t have been able to resolve the issue. If anyone else is struggling with Wyze cam integration, please don’t hesitate to reach out—I’m happy to help!
Happy automating! ![]()
