Troubleshooting Zigbee Lock Notifications: A Success Story
I recently faced a challenge with my smart locks that I thought I’d share in case anyone else is dealing with similar issues. I have a couple of Kwikset 914 Zigbee locks and a Schlage Z-Wave lock, and I wanted to set up notifications based on user codes entered. While the Schlage lock worked seamlessly, the Kwikset locks were a bit of a puzzle.
Initially, I set everything up through SmartThings, but the Zigbee locks weren’t being detected by the default drivers. After some research, I stumbled upon a helpful post where the user recommended using edge drivers for better compatibility. I decided to give it a try and uninstalled the original drivers, re-adding the locks with the new ones. This did the trick—SmartThings now recognizes the locks, and I can add user codes!
However, the notifications weren’t showing up like they do for the Schlage lock. After some experimentation, I realized the issue was with how the user codes were being tracked. I reached out to the community for advice and found that adjusting the lock’s settings in the SmartThings app helped. While it wasn’t as straightforward as the Schlage setup, I managed to get the notifications working by tweaking the automation rules and ensuring the lock’s status was being monitored correctly.
It’s been a bit of a learning curve, but I’m thrilled to have everything up and running smoothly now. If anyone else is struggling with similar issues, don’t hesitate to ask—I’d be happy to share more details about what worked for me!
Overall, I’m really impressed with how reliable these locks are once everything is set up properly. The convenience of having notifications for each user code entry adds an extra layer of security and peace of mind. It’s definitely worth the effort to troubleshoot and get everything working as intended!
