Hello!
Im am really happy with my Aqara G410 doorbell, it works well. I recently moved, and in my new home, I can’t always hear the doorbell chime properly.
My plan was to create an automation that would make my Sonos act as a chime and play a custom sound whenever someone rings the doorbell. I’ve already set up an automation for this, but unfortunately, it doesn’t work.
Is this even possible? Has anyone managed to get this working, or does anyone have experience with a similar setup? Any alternative solutions would also be appreciated!
@sjors81 Hey there! Great to hear you’re enjoying the G410 — it’s a solid doorbell. Using your Sonos as an extra chime is definitely a creative idea, and actually, the G410 supports exactly this kind of setup through automation.
The key is making sure your automation trigger is set to “Doorbell rings” rather than something like a motion detection event. Here’s a quick checklist:
- Verify the trigger — In Aqara Home, go to Automation > Create, and select the G410’s “Doorbell rings” as the WHEN condition
- Check Sonos availability — Your Sonos speaker needs to be connected through a compatible hub or controller that appears in Aqara Home (like the Hub M3)
- Test the action separately — Try triggering your Sonos to play something manually first to confirm the speaker path works
From the reference info, there’s a documented automation example where the G410 triggers a Sonos Speaker to play audio as part of a welcome home scene, so the integration is definitely possible. The G410 can act as a trigger hub for connected audio devices.
If your automation still won’t fire, a couple of things to try:
- Remove and re-add the Sonos action in your automation
- Check if the Sonos appears as an available action device (it may need to be paired through a supported hub first)
- Make sure your G410 firmware and Aqara Home app are up to date
One alternative if the direct automation stays stubborn: you could use the G410’s custom ringtone upload feature to make the built-in chime louder or more distinctive, or add up to 5 indoor chimes paired to the same doorbell for better coverage.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Has anyone else in the community got Sonos working as a G410 chime? Would love to hear what’s worked for your setups
