TTS Configuration and Sound Playback Tips
Hey everyone, I wanted to share my experience with setting up Text-to-Speech (TTS) in Home Assistant and playing sounds through my Raspberry Pi. I recently went through a bit of a learning curve with this, and I thought it might be helpful to document my journey here.
Initially, I followed the official TTS guide and set up the Google TTS platform. Everything seemed straightforward, but I encountered a couple of issues. First, I noticed that when I tried to use the TTS service through the developer tools, the only available call was google_say instead of the generic platform_say. After a bit of research, I realized that this is normal when using the Google TTS platform specifically. It was a bit confusing at first, but it makes sense once you understand how the services are structured.
The second challenge was getting the audio to play through my Raspberry Pi. I installed MPD as suggested, but I ran into an error: Invalid media type. Expected: playlist. This was frustrating because I just wanted to play a simple sound file. After some digging, I found that MPD expects playlists by default, so I needed to adjust my approach. I ended up using a different method involving paplay and gstreamer to play the audio directly without needing a playlist. This worked like a charm and allowed me to integrate TTS with my smart home setup seamlessly.
For anyone else struggling with similar issues, here are a few tips:
  1. Double-check the TTS platform documentation to ensure you’re using the correct service calls.
  2. Experiment with different audio playback methods if MPD isn’t working as expected.
  3. Don’t hesitate to reach out to the community for help—there are plenty of knowledgeable users who can offer guidance.
It’s been a great learning experience, and I’m now able to use TTS for notifications, reminders, and even a bit of fun (scaring my kids with unexpected sounds is a hit around here!). I hope this helps someone else avoid the pitfalls I encountered. Happy tinkering! :headphones::robot:
