I recently installed the Tuya SR208C solar thermal controller and wanted to share my experience and some tips for anyone else looking to set this up. While the initial setup was straightforward via the Tuya app, getting it fully integrated with Home Assistant required a bit of tweaking. Here are some key points I discovered:
Device Recognition: The SR208C was automatically detected by the Tuya app and showed up in Home Assistant without any issues. However, ensuring it’s set to the correct region and time zone was crucial for accurate readings.
Configuration in Home Assistant: I found that manually setting the device type in Home Assistant as a thermostat helped with better integration. This allowed me to control the temperature settings directly from the Home Assistant interface.
Temperature Units: The device supports both Celsius and Fahrenheit, which is great for users in different regions. I recommend double-checking this setting to match your preferences.
Pump Control: One of the standout features is the ability to control the pump remotely. I set up a simple automation where the pump turns on when the temperature difference between the top and bottom of the tank exceeds a certain threshold.
Integration with Other Systems: Pairing this controller with my existing smart thermostat has been a game changer. It automatically adjusts based on the solar panels’ efficiency, which has helped reduce my energy consumption.
Firmware Updates: Keeping the firmware up to date is essential. I noticed improved performance after applying the latest update, which also added a few new features.
If you’re considering this controller, I highly recommend exploring the Home Assistant community for additional configuration ideas and troubleshooting tips. It’s a versatile device that can really enhance your home’s energy efficiency!
Happy smart home tinkering! ![]()
