Hi everyone, I recently purchased a Tuya Zigbee Temperature & Humidity sensor (TS0201) and integrated it into my openHAB setup. While I can successfully pair the device with my deconz gateway and see temperature, humidity, and battery data in the deconz software, I’m facing an issue with openHAB not recognizing the temperature channel.
After pairing, openHAB automatically discovers the device as a ‘TZ3000 Multisensor’, but when I try to add it, I only see the following channels: humidity, last_updated, battery_level, battery_low, and last_seen. The temperature channel is completely missing.
I’ve tried searching for solutions online and came across a similar issue in a forum thread from February 2023. The suggestion was to look for other devices related to the same device ID, but in my case, there doesn’t seem to be any additional devices or channels available.
I’m wondering if there’s a way to force openHAB to recognize the temperature channel or if there’s a workaround to access the temperature data directly. Any advice or insights would be greatly appreciated!
Thanks in advance for your help!
