Does anyone know if this is suitable to be mounted outside under a cover like a lean to?
Hello.many use it like that if you place it under an 3D printed cover as I saw a few for it it will work as this way you protect it by rain or direct sunlight and even heavy dust
Thank you, Before i take a look, are there any you recommend?
Well not sure as that it depends on your taste a sow like 3 different type of cases for the sensor one of them is an bird house ![]()
Here are some :
https://www.printables.com/model/76493-outdoor-sunrain-shield-for-aqara-temperature-humid
https://www.printables.com/model/259152-aqara-sensor-outdoor-housing
https://www.printables.com/model/407266-aqara-xiaomi-temperature-sensor-outdoor-mount
https://www.printables.com/model/926425-aqara-temperature-and-humidity-sensor-outdoor-case
