U100 delay with Apple Watch
Hi there. I have a u100 lock for the garage. When I unlock with the Apple Watch… it beeps and nothing happens. Then I wait for it to sleep and it works the 2nd time. Do I have to wake ithe lock first maybe?
@mikechu88 Hi there! Thanks for sharing your experience with the U100 and Apple Watch. It can be frustrating when the “hands-free” experience isn’t quite as seamless as we’d hope!
Regarding your question, you generally do not need to manually wake the lock. The U100 is designed to respond to Apple Home Key commands via Bluetooth. The behavior you’re describing—where it beeps but doesn’t unlock on the first attempt, then works on the second—often points to a synchronization or connection latency issue rather than a need to “wake” the device.
Here are a few troubleshooting steps that might help stabilize the connection:
  1. Check Bluetooth and Proximity: Ensure Bluetooth is enabled on your iPhone and Apple Watch. The Apple Watch relies on the iPhone’s connection to communicate with the lock if it’s not directly connected via Bluetooth (depending on the model and settings). Being closer to the lock when trying to unlock can help reduce latency.
  2. Verify Home Key Sync: Make sure your Apple Watch is signed in with the same Apple ID as the iPhone used to bind the lock. Sometimes, the Home Key sync can take time or get stuck. You can try turning the “Unlock on Approach” feature off and back on in the Wallet app on your Apple Watch to refresh the connection.
  3. Update Firmware: Ensure your U100 lock firmware is up to date, as updates often improve Bluetooth stability and HomeKit integration.
  4. Restart the Hub: If you are using an Apple Home Hub (like an Apple TV or HomePod) to manage the lock, try restarting it. This can help clear up any temporary network or connection glitches.
If these steps don’t resolve the delay, it might be worth checking if there are any physical obstructions or if the lock needs recalibration, as mechanical issues can sometimes affect sensor response.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
If the issue persists, you can contact customer support for assistance. Please politely reply, "Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, “Please click here” to create a ticket. "
