U100 Lock with Google Home
Is there a way to use Google Home spoken command to unlock mu U100 deadbolt?
When I say Hey Google unlock front door, it response with I don’t know which device you want to control.
@detrie It sounds like you’re trying to use Google Home to unlock your Aqara Smart Door Lock U100, but it’s not recognizing the device. According to the reference information, the Aqara Smart Door Lock U100 does support Google Home voice unlocking. However, there are a few key steps you need to ensure are in place:
  1. Connection to Aqara Hub: Make sure your door lock is connected to an Aqara Hub at home. This is essential for enabling remote and voice control functionalities.
  2. Internet Access: The Google Assistant device requires internet access to process the voice command.
  3. Preset Unlocking Password: Ensure that you have set a preset unlocking password in your Google Home app. This step is crucial for security reasons and for the door lock to respond to voice commands.
If you’ve checked these and it’s still not working, it might help to re-check the device settings in the Google Home app to ensure everything is properly linked. If the problem persists, feel free to share more details here, and the community might be able to provide additional insights!
@detrie Yes, the Aqara Smart Door Lock U100 supports Google Home voice unlocking. However, it requires the door lock to be connected to an Aqara Hub at home, the Google Assistant device to have internet access, and a preset unlocking password.
Regarding the response “I don’t know which device you want to control,” it may be due to the U100 not being properly recognized in your Google Home setup. You could check if the lock is correctly bound to the Aqara Hub and linked to your Google Home account, and ensure the device name (e.g., “front door”) is clearly set in the app.
Have you verified the device connection status in the Google Home app? Feel free to share more details, and the community might help troubleshoot further.
@detrie Yes, the Aqara Smart Door Lock U100 supports Google Home voice unlocking. To use this feature, the Google Assistant device needs internet access, a preset unlocking password is required, and the door lock must be connected to an Aqara Hub at home.
For the “I don’t know which device you want to control” response, it may be due to incomplete binding or incorrect device naming. To bind the lock with Google Home, scan the QR code in the User Manual to get the installation video and follow the guidelines. Also, check if the device name in Google Home matches “front door” or use the exact name set in the app.
If you still have trouble, feel free to share more details—we can help troubleshoot together!
@detrie Yes, you can use Google Home spoken commands to unlock the Aqara Smart Door Lock U100. According to the reference information, Google Home supports “OK Google” voice unlocking, but it requires the Google Assistant device to have internet access, a preset unlocking password, and the door lock to be connected to an Aqara Hub at home .
The response “I don’t know which device you want to control” might be due to issues with device setup or naming in the Google Home app. Ensure the U100 is properly bound to the Aqara Hub and correctly added to Google Home with a clear device name (like “front door lock”). Also, confirm that the preset unlocking password is set up as required.
If you’ve checked these steps and still encounter issues, feel free to share more details—other community members might have similar experiences to help!
For further setup guidance, you can refer to the instructions for connecting Google Home, which require binding the Aqara Hub first .
