U200 adhesive backing replacement
I bought a U200 smart lock and installed it a short while ago, unfortunately because my lock cylinder didn’t allow key unlock from outside with a key inserted inside I removed it while i sorted a replacement cylinder.
I’ve not got a double cylinder that will work, but the adhesive backing to secure the backplate to the lock was so tough I couldn’t remove it cleanly.
  1. Does anyone know how to easily remove the adhesive from the backplate and my doorhandle.
  2. Where can I get a replacement for the adhesive to stick it back onto my handle?
I’m in the UK by the way
I would start by using a hairdryer and carefully heating up the adhesive pad, thereby warming up the glue and then trying gently to remove it. Just be careful because if it’s a painted wood surface too much heat can also damage the paint.
