U200 failing to connect to apple home
As the title says i have two aqara products and both of them are failing to be added to apple home.
Both devices are on the updated firmware : 84
I manage to connect one before the update but for some reason its no more adding again.
I get to match the code however when it gets to preparing the device, i get a fail error.
I do not have an m3 hub, I use iphone 14pro, is that the issue?
Hi, you have any Apple boarder router ? Or you can use a M3 or M100 to bind it to Apple home
Hello @princhipeh
You may need to press the Set button on the lock itself (under the cover near the battery) at the moment of adding and this should work.
